Date/Time: Sat, 23 Nov 2024 20:27:11 +0000
New User
View Count: 1345
[2013-08-18 20:23:57] |
DanielFitzpatrick - Posts: 12 |
Hi , I am a new Sierra User who trades thru Interactive Brokers. I am only using charting at this point. I have linked my Sierra account to IAB. What I am wondering is if that is necessary as I see that Sierra does provide real time prices for futures and stocks. So is it better to use my broker, IAB. Or is it better to just use Sierra. I am wondering which provides better price feed/service, as I use 1 minute and some tick charts. Any links to info etc would be great. Thank you for your support. Daniel Fitzpatrick |
[2013-08-19 17:40:08] |
Whether the Interactive Brokers data feed will be acceptable or not, really is a decision you have to make. As an alternative you could use the Barchart Data Service. Here are instructions for this: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html http://www.sierrachart.com/index.php?l=doc/Barchart.com.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
