Date/Time: Sat, 23 Nov 2024 20:39:32 +0000
dom
View Count: 1603
[2013-08-17 19:25:09]
richbatchelor - Posts: 15
when i set the dom for simple bracket quant 1 it says 2. i move target and stop and on the chart it doesnt change. wierd
[2013-08-17 19:29:00]
infinity seems to work fine
[2013-08-17 22:51:45]
You just need to change the quantity on the Trade Window to 1. Here's the documentation for this:
https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#TradeWindowControls
Set the quantity through the Quantity control.
If you also have 2 targets or 2 stops, you will have a minimum quantity of 2.
Select Global Settings >> Data/Trade Service Settings.
What is the Service set to?
