Date/Time: Sat, 23 Nov 2024 21:42:38 +0000
Measuring the size in pips/points of a Candle-bar (or a range of bars).
View Count: 3932
[2013-08-17 18:54:46] |
User41512 - Posts: 58 |
Hi, Is there a way of being able to measure the number of points/pips between say the top of one candle-bar to the bottom of a different bar, rather than having to manually calculate it, which is what im having to do at the moment. In MT4 for example you can use the cross-hair to measure any distance in pips/points, as you drag the cross-hair it automatically highlights the number of pips. Thks |
[2013-08-17 22:49:03] |
Use the Chart Calculator tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-21 17:44:58] |
nioko54130 - Posts: 108 |
Hello, Can you add the range of the bar with a numeric value in the number bar calculated value studies ? It will be good to measure the volatility on the footprintchart. Thank's |
[2013-08-22 23:10:22] |
For now use the Bar Difference study.
