Date/Time: Sat, 23 Nov 2024 20:56:21 +0000
Alert Manager
View Count: 1483
[2013-08-16 17:43:23]
sandpiper4011 - Posts: 17
gentlemen:
I am using version 1011 -
the alert log in Alert Manager is working fine however each time a new message appears the "Scroll Bar' returns to the top of the scroll bar column. I have searched the documentation and the support messages without a solution.
I tried to activate the scroll bar using the options in the scroll bar column but not able to activate a change. (Even tried turning the monitor upside down but that did't work either
Any help would be appreciated - thks
[2013-08-16 18:35:27]
User53900 - Posts: 5
I am actually not getting any alerts sent to the alert manager via the AddAlertLine function on SC v. 1011 but was on v. 997.
[2013-08-17 00:15:42]
The scrolling problem for the Alert Manager will be resolved.
The problem with sc.AddAlertLine will be resolved in the next release coming out now.
[2013-08-17 05:01:28]
Al SC Developer - Posts: 434
The scrolling issue will be fixed in ver 1013.
