Date/Time: Sat, 23 Nov 2024 21:54:39 +0000
daily pivot points
View Count: 4262
[2013-08-22 13:19:02] |
Dennis B. - Posts: 272 |
http://www.sierrachart.com/image.php?l=1377177494662.png Clearer picture of problem. |
[2013-08-23 04:59:38] |
In the chart posted in post #25 what are the Session Times set to in Chart >> Chart Settings. And what is the Time Zone in Sierra Chart set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-23 13:20:06] |
Start= 09:30 End= 16:15 EST
[2013-08-25 01:16:18] |
M5amhan - Posts: 468 |
the chart in post #25 is exactly what happens to me too it doesnt matter if it is daily, weekly, or monthly pivots, they will all reset at midnight of the previous day and start floating in this chart; red = monthly, green = weekly, blue = daily: http://www.sierrachart.com/image.php?l=1377393282188.png here is a chart when plotted correctly: http://www.sierrachart.com/image.php?l=1377393453705.png Date Time Of Last Edit: 2013-08-25 01:18:04
[2013-08-25 05:11:27] |
This will be resolved in the next release. We are quite sure what is causing this. For now set the Forward Project Pivot Point Lines to No with the Pivot Points study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-25 08:45:43] |
Update to the latest revision by selecting Help >> Download Prerelease. This problem should now be resolved for you.
[2013-08-25 18:42:20] |
the problem is fixed on my end.. thanks
Date Time Of Last Edit: 2013-08-25 19:07:26
[2013-08-25 22:58:30] |
This is good. This actually revealed a significant bug relating to the new feature to adjust the number of forward projection area columns in the chart. So it was good that we determine what was going on. The problem was completely unrelated to Pivot Points.
[2013-08-26 16:07:22] |
http://www.sierrachart.com/image.php?l=1377533167644.png Pivot issue persists. Running ver.1015 |
[2013-08-26 16:50:24] |
How did you update Sierra Chart? Did you use Help >> Download Pre-release?
[2013-08-26 17:34:37] |
No, I downloaded the current release yesterday which was the same as the pre-release. Meaning ver. 1015. Please move on to other issues, I can live with this. Thanks for your efforts. Dennis.... |
[2013-08-26 17:36:26] |
what they are saying is if you go through Help > Download Pre-release through the platform the issue should be resolved
