Date/Time: Sat, 23 Nov 2024 20:54:58 +0000
Number Bars
View Count: 1534
[2013-08-15 17:07:14] |
User93103 - Posts: 48 |
How one can use the information given by Numbers Bars Calculated Values (AskV - BidV). Thanks Ben |
[2013-08-16 08:33:28] |
We can only provide you the technical description for how this is calculated: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#SubgraphDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
