Date/Time: Sat, 23 Nov 2024 20:48:49 +0000
trade size
View Count: 1555
[2013-08-15 16:19:16] |
richbatchelor - Posts: 15 |
where do i set default size for all stocks? say 100 shares |
[2013-08-15 17:43:30] |
This can be done through Global Settings >> Symbol Settings. Here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-15 18:55:01] |
ia ded symbol nugt . def ford quant 100. entered quat 1 on ladder again.???
[2013-08-15 19:45:38] |
enters 100 shares in trading dom , not in chart ladder. odd
[2013-08-16 14:24:05] |
size really doesnt work on chart ladder. always 1 share for all stocks
