Date/Time: Sat, 23 Nov 2024 19:24:48 +0000
Changing Colors on line drawing tools
View Count: 1806
[2013-08-12 18:02:37] |
David L Cresswell - Posts: 1 |
If you have a "line" or similar on the chart you can right click on the line and one option is to "Change Color" and from there you can change to any of the 8 colors listed/shown in the pop up box. How can you change the default colors that appear in that pop up window? Tks |
[2013-08-12 22:00:35] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#QuicklyChangingColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
