Date/Time: Sat, 23 Nov 2024 19:43:52 +0000
Numbers Profile
View Count: 2107
[2013-08-12 07:25:39]
marty_nv - Posts: 85
Thank you for providing market profile as TPO, Volume by Price and Numbers Bars--everso helpful.
Are there plans to provide a "Numbers Profile" as presented by MarketDelta as per the video of "Footprint Profile" in the the following link? This would be an invaluable addition.
http://www.screencast.com/t/LRKP4sv6p2
Date Time Of Last Edit: 2013-08-12 07:32:16
[2013-08-12 10:55:58]
ganz - Posts: 1048
marty_nv
hi
http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#BackgroundTypes
gd lck
[2013-08-12 16:30:17]
Thanks ganz for your reply and linlk. Attached Screenshot shows the mini-profile available with numbers bars compared to the summary profile that could be available through the TPO interface.
imageTPO_and_numbers_2013-08-12_1608.png / V - Attached On 2013-08-12 16:29:11 UTC - Size: 296.46 KB - 540 views
[2013-08-15 07:18:13]
Use the new Numbers Bars version 2 study. You are using Numbers Bars-Old.
Here is the complete documentation for the new study:
http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#Introduction
You should be able to do what you want. Numbers Bars can be used on bars with any timeframe including 1 Day per bar. You can create a very detailed Numbers Bar for an entire day.
