Date/Time: Sat, 23 Nov 2024 19:29:10 +0000
BUY/SELL order trigger
View Count: 1526
[2013-08-10 15:23:30] |
User25261 - Posts: 24 |
HI, First thanks for the good support offering here. I want to know if there is any option to trigger a buy/sell order by a moving average crossover? Its almost the same Principe of the alert signal when this crossover happen but instead of the alert signal i want a order get trigged when this happen. I appreciate any kind of help. Thanks |
[2013-08-10 23:46:37] |
Yes there is. We recommend using the Spreadsheet System for Trading study to do this. Complete documentation can be found here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-11 22:39:29] |
HI, i want to put this formula:=CROSSFROMBELOW(E3:E4,AA3:AA4) in K3 but it dosnt work,i get a spreadsheet gear:invalid formula Can you help please? |
[2013-08-11 23:29:43] |
Select Global Settings >>Spreadsheet Settings. Set the Region to "English (United States)". Press OK. Try reentering the formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-12 00:43:17] |
HI, Thanks for your reply and help:) I follow all the steeps described in the example given by SC. Now when i back tested i dont get the info in my chart trading DOM and i dont get the order fills value showed in the chart and its the same when im using it right now with live data,the price cross the MA several time but i dont get any sign of fills in my DOM. Can you please help with some solution? Thanks |
[2013-08-12 00:53:58] |
First please look over the information in this section here about ignored signals: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#IgnoredSignals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
