Date/Time: Sat, 23 Nov 2024 19:31:55 +0000
Volume bars different from my IB data provider
View Count: 1494
[2013-08-09 19:09:56] |
User40526 - Posts: 166 |
The volume bars on Sierra Chart for the same instrument and time frame are very different from my Interactive Broker charts, which is the B/D I use and is also the data provider I am using for Sierra Charts. Suggestions?
[2013-08-09 19:24:37] |
Make sure Global Settings >>Data/Trade Service Settings >> More Interactive Brokers Settings >> Simulate Trades to Match Daily Volume is enabled.
