Date/Time: Sat, 23 Nov 2024 19:44:17 +0000
Advisor Acct Positions
View Count: 1393
[2013-08-09 06:57:48] |
JohnL - Posts: 27 |
After upgrading to 1007, my trade positions window shows correct positions (long 1 each) for sub-accounts, but the F account shows as flat so my chart and trade window shows flat. I guess this is technically correct, but not very helpful. Maybe I have something configured incorrectly? How can I display the aggregate position of the sub-accounts? |
[2013-08-09 07:12:07] |
Sierra Chart is no longer going to combine the position data from subaccounts. What you can do is use the order fill calculated position for the main account: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#UsingIndependentInternalPositions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
