Date/Time: Sat, 23 Nov 2024 19:39:47 +0000
User Email Questions - Display Chart without Seconds on the X-axis for Time
View Count: 1718
[2013-08-09 04:27:38]
Sierra Chart - Max - Posts: 5730
If seconds are shown on the x-axis for time, how do I change it so the chart will only display hour and minutes on x-axis? Thank you.
Sierra Chart Support
[2013-08-12 17:43:09]
You cannot remove the seconds. Whether you see the seconds or not depends upon the Bar Period Type and the time length of the bars.
If the chart bars are set to 1 minute per bar or some multiple of a minute, then you will not see the seconds.
Date Time Of Last Edit: 2013-08-12 17:44:03
[2013-08-14 02:38:50]
Thank you for your response. The time period for each bar is set to 5 minutes. For some reasons, the seconds did not show up for one-minute bar on other charts.
[2013-08-15 04:18:28]
Please post an image of the chart, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
And then we need to know what Session Start Time is in Chart >> Chart Settings.
