Date/Time: Sat, 23 Nov 2024 21:34:01 +0000
Installed on new computer ? Indicators not there anymore ?
View Count: 1528
[2013-08-08 12:08:47] |
lushyvo - Posts: 2 |
What happened to indicators under ANALYSIS eg: Where is: > Based on Examples (great indicator) where can I find this or how do I get this back? > 60 MT -cash, 60 MT futures etc, etc Where do I find this again on new installation on computer. I hope they did not take this away..... Thank you |
[2013-08-08 16:22:53] |
Sierra Chart - Max - Posts: 5730 |
You can find the files here: http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php If you would like to copy your Sierra Chart settings and data files from your other computer, refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support Date Time Of Last Edit: 2013-08-08 16:31:39
[2013-08-08 16:31:05] |
We have set your account to have those particular study collections automatically installed when you start Sierra Chart. Restart Sierra Chart to get them. You will see them listed under Analysis after the restart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-25 17:46:48] |
I restarted my sierra charts and the ( Based on Examples ) indicator did not show under Analysis. What do I have to do to get this to work? |
[2013-08-25 23:23:12] |
We see you are running version 866. This is an older version of Sierra Chart. It does not support automatic downloading of study collection files on startup. Update Sierra Chart by selecting Help >> Download Current Version.
