Date/Time: Sat, 23 Nov 2024 19:59:16 +0000
User Email Questions - Fib Numbers
View Count: 1533
[2013-08-07 21:30:38]
Sierra Chart - Max - Posts: 5730
My Fib numbers change as I change from a daily chart to a 5 min chart. I have the Fib based on daily OHLC study. Is there a fix for this?
Thanks,
Sierra Chart Support
[2013-08-07 22:18:16]
Specifically what drawing tool or what study are you referring to?
[2013-08-08 17:20:48]
And do you have the Session Times for the Intraday chart set correctly in Chart >> Chart Settings. They need to correspond to the actual exchange session times. Refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes
