Date/Time: Sat, 23 Nov 2024 19:16:08 +0000
Backtest within a peirod of time for each trading day via spreadsheet
View Count: 1915
[2013-08-07 13:04:50] |
moonmist - Posts: 127 |
Hi, Is it possible to backtest signals generated within a specific period of time ? For example, I like to have results for ES futures between 8:00 AM and 4:00 PM Eastern Time only. What is the easiest way to achieve this ? Using some DateTime functions of the spreadsheet ? Thanks. Date Time Of Last Edit: 2013-08-07 14:13:16
[2013-08-07 13:13:16] |
Sawtooth - Posts: 4118 |
One of these formula examples will get you started: http://www.sawtoothtrade.com/example-4.html Date Time Of Last Edit: 2015-08-14 01:40:35
[2013-08-07 17:05:55] |
The main method to accomplish this is to set the Session Times to what you require through Chart >> Chart Settings.
