Date/Time: Sat, 23 Nov 2024 19:12:30 +0000
Cannot connect to data
View Count: 1598
[2013-08-07 00:48:41] |
cloudchartist - Posts: 32 |
Trying to connect to T4 data, waiting to reconnect. Here is Message Log: Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:23:26 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:23:26 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:23:26 Disconnected from CTS T4. | 2013-08-06 20:23:26 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:23:26 Connecting to CTS T4 Simulation server. | 2013-08-06 20:26:26 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:26:29 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:26:29 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:26:29 Disconnected from CTS T4. | 2013-08-06 20:26:29 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:26:29 Connecting to CTS T4 Simulation server. | 2013-08-06 20:29:29 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:29:33 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:29:33 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:29:33 Disconnected from CTS T4. | 2013-08-06 20:29:33 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:29:33 Connecting to CTS T4 Simulation server. | 2013-08-06 20:32:33 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:32:36 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:32:36 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:32:36 Disconnected from CTS T4. | 2013-08-06 20:32:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:32:36 Connecting to CTS T4 Simulation server. | 2013-08-06 20:33:18 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:33:21 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:33:21 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:33:21 Disconnected from CTS T4. | 2013-08-06 20:33:21 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:33:21 Connecting to CTS T4 Simulation server. | 2013-08-06 20:36:21 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:36:24 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:36:24 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:36:24 Disconnected from CTS T4. | 2013-08-06 20:36:24 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:36:24 Connecting to CTS T4 Simulation server. | 2013-08-06 20:39:24 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:39:29 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:39:29 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:39:29 Disconnected from CTS T4. | 2013-08-06 20:39:29 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:39:29 Connecting to CTS T4 Simulation server. | 2013-08-06 20:42:29 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:42:32 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:42:32 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:42:32 Disconnected from CTS T4. | 2013-08-06 20:42:32 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:42:32 Connecting to CTS T4 Simulation server. | 2013-08-06 20:45:32 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:45:35 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:45:35 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:45:35 Disconnected from CTS T4. | 2013-08-06 20:45:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:45:35 Connecting to CTS T4 Simulation server. | 2013-08-06 20:46:10 Failed to login to CTS T4. Reason: Failed | 2013-08-06 20:46:13 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 20:46:13 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 20:46:13 Disconnected from CTS T4. | 2013-08-06 20:46:14 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 20:46:14 Active service: CTS T4 | 2013-08-06 20:46:25 |
[2013-08-07 01:51:48] |
Please contact Top Step Trader about this. We are unable to help you with this.
