Date/Time: Sat, 23 Nov 2024 18:50:42 +0000
Move chart with its drawing tools to another PC
View Count: 1455
[2013-08-06 19:49:22] |
JP - Posts: 24 |
Could someone please explain if it is possible to move a chart with its drawing tools (lines, drawings, etc... (not the studies)) to another PC? Thank you. |
[2013-08-06 20:39:31] |
Copy the Chartbook from one Sierra Chart installation to another. The Chartbooks are located in the Sierra Chart Data folder. The location of this folder can be found through Global Settings >> General Settings >> Data Files Folder.
