Date/Time: Sat, 23 Nov 2024 18:47:23 +0000
1004: T&S Window bug
View Count: 1415
[2013-08-06 16:46:40] |
joshtrader - Posts: 488 |
If "Show Title Bar" is enabled in T&S and auto-hide is turned on, the title bar disappears and reappears repeatedly when it is not in focus. If "Show Title Bar" is unchecked, there is no title bar to display and thus the error does not present itself.
[2013-08-06 18:23:18] |
This will be resolved.
