Date/Time: Sat, 23 Nov 2024 19:29:41 +0000
volume and TPO chart
View Count: 2232
[2013-08-06 15:13:41]
saxo12 - Posts: 38
1/ Is it possible to get total text volume to one side of the TPO chart
without the volume profile (ie it encroaches onto the letters)
2/And the new text volume coming in on the current bar in a separate column
3/Also can the distance between the letters be reduced, without 'squeezing' the chart down
Date Time Of Last Edit: 2013-08-06 16:58:01
[2013-08-08 04:47:54]
1, 2. We are not clear as to exactly what you are looking for. However it sounds as though you do need to use the Volume by Price study.
3. Yes. Decrease the TPO Letter/Block Price Increment in Ticks input setting with the TPO Profile Chart study.
Date Time Of Last Edit: 2013-08-08 04:48:22
[2013-08-08 14:49:10]
saxo12 - Posts: 38
1/ want the total volume at the price without the profile ie text only to the left of the market profile
2/have 30 min bars printing for the profile and want to see the new volume printing to the now developing 30 min bar to one side of the total volume already accumulated
1/first column total vol (vol profile not wanted}
2/second column new vol coming in
third 'column' TPO profile
3/ do I have to pay for charts again on second computer,
get 'windows error 5' 'access denied' on second computer
Date Time Of Last Edit: 2013-08-08 14:53:57
[2013-08-10 02:21:37]
1. This be possible by making the volume profile not wide and using an outline (Draw Volume Profile Outline Only = Yes). Refer to this image:
http://www.sierrachart.com/image.php?l=1376100928937.png
2. For this, we recommend setting up a 2nd chart and setting the chart bars to 30 minutes per bar and using single bar volume profiles as documented here:
http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#SingleBarVolumeProfiles
3. No, you do not have to pay extra. For help with the access denied error, refer to:
http://www.sierrachart.com/index.php?l=doc/helpdetails16.html
Date Time Of Last Edit: 2013-08-10 02:22:07
[2013-08-10 02:32:49]
1. We added this to our examples and provided further details:
http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#ExampleImages
Hopefully, this should get you started with this kind of configuration.
Date Time Of Last Edit: 2013-08-10 02:32:59
