Date/Time: Sat, 23 Nov 2024 18:40:03 +0000
Do you support Rithmic sub second timestamps
View Count: 1524
[2013-08-06 08:58:15]
Hendrixon - Posts: 130
SCDateTimeMS DateTimeMS;
DateTimeMS = sc.BaseDateTimeIn[sc.Index];
BarTimeMS[sc.Index] = DateTimeMS.GetMilliSecond();
Used on volume and tick bars this gives just zeros.
Data file is saved as 1 tick and recorded live (not backfill).
Don't know if it should show there, but exporting the data file to text shows the timestamps there as regular HH:MM:SS (no millisecond feild).
SC version 1003.
[2013-08-06 19:36:07]
We do not use the Rithmic provided millisecond timestamps. Sierra Chart has its own millisecond time stamping that it uses.
In the next version of Sierra Chart if you use the Chart Values tool and look at the Tool Values Window, you will see the milliseconds displayed if you switch down to a 1 tick chart.
