Date/Time: Sat, 23 Nov 2024 19:38:53 +0000
CTS FIX error message
View Count: 3124
[2013-08-05 01:28:09]
N!co - Posts: 140
I updated to version 1004
I followed these steps http://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX
now I get these error mesages ??
Requesting market depth updates for: ES.CME_20130900_ESU3.CME_Eq if supported. | 2013-08-05 01:46:19
Unsubscribed from market depth data for ES.CME_20130900_ESU3.CME_Eq | 2013-08-05 01:50:44
Requesting market depth updates for: YM.CME_20130900_YMU3.CME_E if supported. | 2013-08-05 01:50:44
Unsubscribed from market depth data for YM.CME_20130900_YMU3.CME_E | 2013-08-05 01:52:34
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-05 01:52:34
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-05 01:52:39
Requesting market depth updates for: ZN.CME_20130900_ZNU3.CME_F if supported. | 2013-08-05 01:52:39
Unsubscribed from market depth data for ZN.CME_20130900_ZNU3.CME_F | 2013-08-05 01:53:04
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-05 01:53:04
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-05 02:20:07
Requesting market depth updates for: YM.CME_20130900_YMU3.CME_E if supported. | 2013-08-05 02:20:07
Unsubscribed from market depth data for YM.CME_20130900_YMU3.CME_E | 2013-08-05 02:20:12
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-05 02:20:12
CTS FIX: Can not get Account Orders. The given account is empty. | 2013-08-05 02:24:01
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-05 02:30:03
Requesting market depth updates for: YM.CME_20130900_YMU3.CME_E if supported. | 2013-08-05 02:30:03
Unsubscribed from market depth data for YM.CME_20130900_YMU3.CME_E | 2013-08-05 02:40:24
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-05 02:40:24
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-05 03:20:58
Requesting market depth updates for: ES.CME_20130900_ESU3.CME_Eq if supported. | 2013-08-05 03:20:58
Unsubscribed from market depth data for ES.CME_20130900_ESU3.CME_Eq | 2013-08-05 03:21:03
Requesting market depth updates for: YM.CME_20130900_YMU3.CME_E if supported. | 2013-08-05 03:21:03
CTS FIX: Can not get Account Orders. The given account is empty. | 2013-08-05 03:24:01
also see screenshot, this was showing different before
Date Time Of Last Edit: 2013-08-05 01:33:32
imagereadingdata.PNG / V - Attached On 2013-08-05 01:32:34 UTC - Size: 1.18 KB - 579 views
[2013-08-05 10:22:15]
1. The messages about requesting market depth data and unsubscribing are normal.
2. The Reading Data status message still displaying on the Status Bar even if there is no data being read has been resolved. Please update again by selecting Help >> Download Prerelease.
3. Go to a chart and select Trade >> Open Trade Window for Chart. What do you see in the list of accounts on the Trade Window? Refer here for instructions for the list of accounts:
https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#SelectingTradeAccount
Do you see your trade account ID?
Date Time Of Last Edit: 2013-08-05 10:22:51
[2013-08-05 16:27:22]
N!co - Posts: 140
Hi
Idownloaded the prerelease,
now i get this error message and Sierrachart will not run anymore, it doesn't get passed the error message
see screenshot
imageprerelease error.PNG / V - Attached On 2013-08-05 16:27:17 UTC - Size: 12.08 KB - 513 views
[2013-08-05 16:28:02]
Yes, we are aware of this in some cases and we are working to resolve it.
[2013-08-05 16:30:58]
We will update this thread when this problem is resolved.
For now please go back to the current version:
http://www.sierrachart.com/downloads/SierraChartSetup.exe
[2013-08-05 16:34:00]
ymlee - Posts: 23
Hi Nico,
I have 3 instances of SC, I having the same problem for 2 of the instances.
I solve this problem by using direct download from Pre-release webpage and reinstall SC.
[2013-08-05 16:34:38]
N!co - Posts: 140
i did, but the problem is that that version can't open my chartbooks :(
somehow i can't seem to find the version i was on before i downloaded the prerelease
i believe it was version 1000 but that one isn't on the site
hope you get this solved quicky
[2013-08-05 16:39:24]
Sawtooth - Posts: 4118
To access backup chartbooks, take a look at this:
https://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook
[2013-08-05 16:51:28]
Could you please update again by selecting Help >> Download Prerelease and let us know if you still see the problem or not. We have put out a new revision. Our initial testing show the problem is resolved.
[2013-08-05 16:52:41]
ymlee - Posts: 23
Hi Nico,
You are right, I only able to run SC if I select "Run SierraChart" after installation.
But after I closed SC and try to re-run it, the same message popup.
[2013-08-05 16:54:09]
N!co - Posts: 140
ymlee, thx
although i already tried that aswell, I redownloaded the 1004 version form the site
AND
when it asked in the end " run sierrachart" , this time i clicked NO
then start SC the normal way, I have it now running
[2013-08-05 17:11:29]
ymlee - Posts: 23
I thk SC support solved the problem for us, now is version 1005.
[2013-08-05 20:01:59]
N!co - Posts: 140
SC support,
new error message poping up al the time
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-05 20:33:46
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-05 20:33:51
Requesting market depth updates for: FGBM.E_FGBM_201309.E_BND if supported. | 2013-08-05 20:33:51
Unsubscribed from market depth data for FGBM.E_FGBM_201309.E_BND | 2013-08-05 20:34:01
Requesting market depth updates for: FGBL.E_FGBL_201309.E_BND if supported. | 2013-08-05 20:34:01
Unsubscribed from market depth data for FGBL.E_FGBL_201309.E_BND | 2013-08-05 20:34:11
Requesting market depth updates for: YM.CME_20130900_YMU3.CME_E if supported. | 2013-08-05 20:34:11
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 21:59:59
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:00
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:01
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:02
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:03
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:04
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:05
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:06
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:07
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:12
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:13
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:14
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:17
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:20
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:23
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:31
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:32
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:40
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:43
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:51
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:52
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:56
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:00:57
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:04
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:09
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:11
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:12
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:14
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:15
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:16
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:17
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:18
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:19
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:20
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:21
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:22
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:24
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:25
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:30
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-05 22:01:31
[2013-08-05 22:46:05]
We will let CTS know about this.
[2013-08-05 22:56:14]
Do you see this at the current moment?
[2013-08-05 23:22:38]
Could you answer the following questions for us:
In the copy of Sierra Chart they use with CTS, what is your Time Zone setting(Global Settings >> Data/Trade Service Settings)?
Are you connected to a Live or Simulation CTS account?
[2013-08-05 23:25:41]
N!co - Posts: 140
timezone : Brussels
Live CTS account
[2013-08-06 18:04:35]
CTS is asking us what your Username and Firm are in Global Settings >>Data/Trade Service Settings. Please provide us this information through an Account Support Ticket:
https://www.sierrachart.com/usercp.php?page=SupportTickets
[2013-08-06 18:08:51]
N!co - Posts: 140
sent an account support ticket
[2013-08-06 20:04:25]
N!co - Posts: 140
SC support, just to inform you
the same error message appeared at the exact same time as it did yesterday
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 21:59:59
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:00
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:03
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:05
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:06
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:07
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:08
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:12
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:13
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:14
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:20
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:23
TradeDateTime (00:00:00) in InternalUpdateTrade is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2013-08-06 22:00:26
[2013-08-07 07:14:06]
N!co - Posts: 140
SC support,
here are few more issues with version 1005
1. I follow 4 european markets ( eurex futures) these are ESTX50, DAX, BUND and BOBL
normaly these 4 markets trad trading at 08h00 am Brussel time
Although thc the CTS platform they start tradign at 008h00 am , in Sierra chart only the BOBL symbol
does start trading
ESXT50, DAX and BUND do not want to start charting until I do a disconnect and reconnect !!
2. I can't get data for symbol :CME_Fo-E7-CME_20130900_E7U3
Requesting market depth updates for: FGBL.E_FGBL_201309.E_BND if supported. | 2013-08-07 08:35:45
Unsubscribed from market depth data for FGBL.E_FGBL_201309.E_BND | 2013-08-07 08:37:20
Requesting market depth updates for: FDAX.E_FDAX_201309.E_INX if supported. | 2013-08-07 08:37:20
Unsubscribed from market depth data for FDAX.E_FDAX_201309.E_INX | 2013-08-07 08:37:25
Requesting market depth updates for: 6E.CME_20130900_6EU3.CME_Fo if supported. | 2013-08-07 08:37:25
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\3\Data\CME_Fo-E7-CME_20130900_E7U3.scid | 2013-08-07 08:38:10
Starting updates for: CME_Fo-E7-CME_20130900_E7U3 | 2013-08-07 08:38:11
Symbol Error: CME_Fo-E7-CME_20130900_E7U3 is unknown, unavailable, or improperly formatted. CTS FIX: Symbol format needs to be [contract].[market].[exchange]. | 2013-08-07 08:38:11
HD Request # 50 - Downloading Intraday chart data for CME_Fo-E7-CME_20130900_E7U3 to the file CME_Fo-E7-CME_20130900_E7U3.scid. Service: cts | 2013-08-07 08:38:11
CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-07 08:38:11
The network socket is connected. | 2013-08-07 08:38:12
The socket starting SSL connection. | 2013-08-07 08:38:12
SSL socket is now connected. | 2013-08-07 08:38:12
CTS Historical FIX Session: Sending the Logon message. | 2013-08-07 08:38:12
CTS Historical FIX Session: Connected to Historical data server. | 2013-08-07 08:38:13
HD Request # 50 - CTS Historical FIX Session. Invalid symbol format. Needs to be [contract].[market].[exchange]. Symbol: CME_Fo-E7-CME_20130900_E7U3 | 2013-08-07 08:38:13
Unsubscribed from market depth data for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-07 08:39:01
Requesting market depth updates for: ZN.CME_20130900_ZNU3.CME_F if supported. | 2013-08-07 08:39:01
Unsubscribed from market depth data for ZN.CME_20130900_ZNU3.CME_F | 2013-08-07 08:39:11
Requesting market depth updates for: ES.CME_20130900_ESU3.CME_Eq if supported. | 2013-08-07 08:39:11
CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-07 08:39:13
CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-07 08:39:13
The SSL socket was shut down successfully. | 2013-08-07 08:39:13
CTS Historical FIX Session: Logged out and disconnected. | 2013-08-07 08:39:13
CTS Historical FIX Session: Disconnected. | 2013-08-07 08:39:13
HD Request # 50 - Error downloading historical Intraday data for CME_Fo-E7-CME_20130900_E7U3. There was a communication error with the server. | 2013-08-07 08:39:13
HD Request # 50 - Received 0 records and wrote 0 records for CME_Fo-E7-CME_20130900_E7U3 | 2013-08-07 08:39:13
HD Request # 50 - Intraday download COMPLETE for CME_Fo-E7-CME_20130900_E7U3 | 2013-08-07 08:39:13
Real-time intraday chart data file updates started for CME_Fo-E7-CME_20130900_E7U3 | 2013-08-07 08:39:13
Ignored socket Close call based on current socket state. | 2013-08-07 08:39:13
Unsubscribed from market depth data for ES.CME_20130900_ESU3.CME_Eq | 2013-08-07 08:39:36
Requesting market depth updates for: 6E.CME_20130900_6EU3.CME_Fo if supported. | 2013-08-07 08:39:36
Unsubscribed from market depth data for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-07 08:39:41
Requesting market depth updates for: ES.CME_20130900_ESU3.CME_Eq if supported. | 2013-08-07 08:39:41
Unsubscribed from market depth data for ES.CME_20130900_ESU3.CME_Eq | 2013-08-07 08:39:51
Requesting market depth updates for: ZN.CME_20130900_ZNU3.CME_F if supported. | 2013-08-07 08:39:51
3. i can not get data for symbol: CME_Fo-J7-CME_20130900_J7U3
Requesting market depth updates for: ZB.CME_20130900_ZBU3.CME_F if supported. | 2013-08-07 09:02:53
Unsubscribed from market depth data for ZB.CME_20130900_ZBU3.CME_F | 2013-08-07 09:02:58
Requesting market depth updates for: FDAX.E_FDAX_201309.E_INX if supported. | 2013-08-07 09:02:58
Unsubscribed from market depth data for FDAX.E_FDAX_201309.E_INX | 2013-08-07 09:03:08
Requesting market depth updates for: 6E.CME_20130900_6EU3.CME_Fo if supported. | 2013-08-07 09:03:08
Unsubscribed from market depth data for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-07 09:03:13
Requesting market depth updates for: 6J.CME_20130900_6JU3.CME_Fo if supported. | 2013-08-07 09:03:13
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\3\Data\CME_Fo-J7-CME_20130900_J7U3.scid | 2013-08-07 09:03:54
Starting updates for: CME_Fo-J7-CME_20130900_J7U3 | 2013-08-07 09:03:54
Symbol Error: CME_Fo-J7-CME_20130900_J7U3 is unknown, unavailable, or improperly formatted. CTS FIX: Symbol format needs to be [contract].[market].[exchange]. | 2013-08-07 09:03:54
HD Request # 51 - Downloading Intraday chart data for CME_Fo-J7-CME_20130900_J7U3 to the file CME_Fo-J7-CME_20130900_J7U3.scid. Service: cts | 2013-08-07 09:03:54
Compressing file: C:\SierraChart\3\Data\CME_Fo-J7-CME_20130900_J7U3.scid. This may take a while... | 2013-08-07 09:03:54
CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-07 09:03:54
Error connecting socket: Windows error code 10060: Een verbindingspoging is mislukt omdat de verbonden party niet correct heeft geantwoord na een bepaalde tijd, of de gemaakte verbinding is mislukt omdat de verbonden host niet heeft geantwoord. | 2013-08-07 09:04:16
CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-07 09:04:16
CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-07 09:04:16
CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-07 09:04:21
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\3\Data\CME_Fo-E7-CME_20130900_E7U3.scid | 2013-08-07 09:04:37
Error connecting socket: Windows error code 10060: Een verbindingspoging is mislukt omdat de verbonden party niet correct heeft geantwoord na een bepaalde tijd, of de gemaakte verbinding is mislukt omdat de verbonden host niet heeft geantwoord. | 2013-08-07 09:04:42
CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-07 09:04:42
CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-07 09:04:42
CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-07 09:04:47
The network socket is connected. | 2013-08-07 09:04:47
The socket starting SSL connection. | 2013-08-07 09:04:47
SSL socket is now connected. | 2013-08-07 09:04:48
CTS Historical FIX Session: Sending the Logon message. | 2013-08-07 09:04:48
CTS Historical FIX Session: Connected to Historical data server. | 2013-08-07 09:04:49
HD Request # 51 - CTS Historical FIX Session. Invalid symbol format. Needs to be [contract].[market].[exchange]. Symbol: CME_Fo-J7-CME_20130900_J7U3 | 2013-08-07 09:04:49
4. problems with the full sized currency contracts,
6E.CME_20130900_6EU3.CME_Fo and
see screenshots
imageproblem 6e.PNG / V - Attached On 2013-08-07 07:12:17 UTC - Size: 102.64 KB - 562 views
imageproblem 6j.PNG / V - Attached On 2013-08-07 07:12:27 UTC - Size: 88.15 KB - 567 views
[2013-08-07 21:01:12]
Just to let you know, we are thoroughly reviewing this and will respond.
[2013-08-08 04:27:00]
This problem is fixed but not yet released.:
[2013-08-08 04:38:35]
1. We are going to advise CTS about this problem.
2. We see 2 problems related to getting market data for CME_Fo-E7-CME_20130900_E7U3
One of these we have resolved.
The 2nd problem is you are using the wrong symbol. This is the old symbol format. Follow these instructions here to change the symbol of the chart:
3. Same as #2. CME_Fo-J7-CME_20130900_J7U3 is not the right format.
4. We think we know what you are trying to show in these chart images. However, next time, please provide us a chart without any studies, and set to 1 minute per bar the case of an Intraday chart.
This problem has been pointed out to us by another user and reported to CTS. We are still waiting for an answer and resolution.
There are a lot of issues you have brought to our attention, please wait until CTS gets these resolved and we are also going to put out a new release tomorrow.
[2013-08-08 10:20:34]
N!co - Posts: 140
as requested a 1 minute chart
image1min.PNG / V - Attached On 2013-08-08 10:20:28 UTC - Size: 93.13 KB - 539 views
