Date/Time: Sat, 23 Nov 2024 17:42:22 +0000
Data Error
View Count: 1601
[2013-08-04 19:04:16] |
User39772 - Posts: 311 |
Please take a look to http://www.sierrachart.com/image.php?l=1375642883876.png As you can see there is data of several days mixed. 8-1, than 8-2, than 8-1 again. This leads to false charts. This is the case in all of my symbols in the watchlist. How can I solve this for all symbols ? Date Time Of Last Edit: 2013-08-04 20:21:26
[2013-08-04 20:23:09] |
Go to the chart and select Edit >>Delete All Data and Download. Or, right-click before the out of order dates and then select Delete Data and Download. It sounds as though you had a problem with your computer's clock which was incorrect at a point in time. There is also the command Delete and Download Data-All Charts that can be added to the Chart Shortcut menu through Global Settings >> Customize Chart Shortcut Menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-04 20:25:09
[2013-08-04 20:25:27] |
The prior post has been corrected.
