Date/Time: Sat, 23 Nov 2024 18:37:39 +0000
Nees help with pivot range
View Count: 2103
[2013-08-04 16:03:25]
User25261 - Posts: 24
HI,
Did you have some indicator or tool which help me to calculate the PIVOT RANGE?
[2013-08-04 22:07:59]
Yes. Use the Study Subgraph Difference study.:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s185
Assuming you want to calculate the difference between 2 Pivot Point lines.
Date Time Of Last Edit: 2013-08-04 22:46:02
[2013-08-04 23:31:07]
you dont have any study(like other platform)which i can use directly without loosing time to figure how to do this?
[2013-08-04 23:34:33]
i attach an example in the picture to give an idea about what i want.i get this just by using one click
imagebbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb.jpg / V - Attached On 2013-08-04 23:34:26 UTC - Size: 207.08 KB - 535 views
[2013-08-04 23:41:22]
That is a very complex image and presents lots of information. We do not know all of the formulas involved in what is being presented. We do not even know what you are referring to in that image. And it also is not true that another program will provide that kind of set up with a single click without any pre-configuration ahead of time. Someone must have programmed all of that ahead of time and understood exactly what they wanted to do. You are going to have to put some effort into this. There is no other possibility here. You cannot just throw an image at us, and expect that we know exactly what you want to do.
What is the formula of what you want to do?
Date Time Of Last Edit: 2013-08-04 23:42:42
[2013-08-05 00:02:08]
hi,
this is what i want:
Pivot range high = daily pivot price + pivot differential
Pivot range low = daily pivot price – pivot differential
and here more info:
daily pivot price = (high + low + close) / 3
Second number = (high + Low) / 2
Pivot differential = daily pivot price – second number
Can you programme this?
[2013-08-05 17:33:46]
Yes we can do this. We will add a new study.
[2013-08-06 01:43:13]
In the next release there will be a study named Pivot Range-Variable Period. This should be out in a day or 2.
