Date/Time: Sat, 23 Nov 2024 17:42:52 +0000
graphics bug ?
View Count: 1777
[2013-08-04 02:31:53]
SKY - Posts: 45
Hi
looks there is a problem w/ Sierra's graphics
pls see attached file
see the white lines that appear on the greem horizontal strips
Tnx.
imageSierraBug.png / V - Attached On 2013-08-04 02:31:48 UTC - Size: 48.56 KB - 650 views
[2013-08-04 04:02:44]
Looks like you have a Gann Grid drawing on the chart. Look for this through Tools >> Manage Chart Drawings Window.
[2013-08-04 05:53:10]
SKY - Posts: 45
no - it is NOT a Gann Grid
BTW - this is an imported drawing object that appears that way at the importer only
when i change the spacing between candles - at some point the grid disappears.
2nd thought - may be it is a gann grid which is generated out of a bug ... for sure it is NOT
out of intended settings (in my case i don't use GANN ... i'm using a new methodology that i
have developed - Value-Profile(c) - but this methodology has nothing to do w/ grids or any other
indicator/oscillator and so on ...
Pls check it out and advise what is the problem ... it really bothers during
[2013-08-04 05:55:38]
SKY - Posts: 45
it really bothers during trading time as it breaks the candles image especially the tails when price are there
so it is important to resolve this issue
i have 2 display devices and the problem stays as i frag the window over the 2 displays ... this is a Sierra issue
tnx!
[2013-08-04 06:39:27]
SKY - Posts: 45
pls take a look at the 2 attched files
the very same chart appears at both files - the only difference is
that candles spacing
hope it helps
imageSierrabug01.png / V - Attached On 2013-08-04 06:39:06 UTC - Size: 30.65 KB - 512 views
imageSierrabug02.png / V - Attached On 2013-08-04 06:39:13 UTC - Size: 23.29 KB - 564 views
[2013-08-05 01:46:09]
Please provide a Chartbook containing a chart which shows this problem, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
Date Time Of Last Edit: 2013-08-05 01:46:24
