Date/Time: Sat, 23 Nov 2024 18:21:30 +0000
Question on sharing sierra chart configuration
View Count: 1523
[2013-08-03 02:22:59] |
DECRASH - Posts: 10 |
I have a significant amount of toolbar configurations, etc. How do I send this exact set up to another computer or person who uses sierra chart? The goal is to have that computer or person retrieve a sierra chart file containing configurations and load it onto his sierra chart thus cutting his configuration time.
[2013-08-03 03:40:37] |
Send them the Sierra3.cfg file. This file is not contain any account information. They need to take this file and place it into their Sierra Chart program folder (usually C:\SierraChart) when Sierra Chart is not running.
