Date/Time: Sat, 23 Nov 2024 17:42:41 +0000
Confirmations
View Count: 1693
[2013-08-02 13:46:41]
User29707 - Posts: 43
No trade confirmations selected but confirmaiton window still pops up requesting confirmation..what I am I doing wrong. Also want selection remembered so I do not have to select it every time I load SC
[2013-08-02 13:49:07]
This is for trading DOM only. Seems to work OK for trade window. Is there another selection for confirmations on the trading dom other thn the M button on the trading window?
[2013-08-02 21:49:13]
Once you get the Trade DOM configured the way you want, you need to save it as part of the Chartbook. Follow the instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html
You must not have the confirmations disabled specifically for the particular Trade DOM. Go to the Trade DOM and select Trade >>Open Trade Window for Chart. Then disable the confirmations through Menu >> Confirmations on the attached Trade Window. We cannot see why there would be any problem with this.
Date Time Of Last Edit: 2013-08-17 23:14:11
