Date/Time: Sat, 23 Nov 2024 16:55:19 +0000
Trading DOM
View Count: 1776
[2013-08-01 18:12:26]
User29707 - Posts: 43
Can I link the Trading DOM to the chart (not on the chart), so that the DOM will change with the chart when I change the chart symbol.
Currently, I select a chart and then open a trading DOM, if I change the symbol for the chart the DOM symbol stays as first opened
[2013-08-02 11:33:06]
Yes, by using the Chart Linking feature:
https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChartLinking
[2013-08-02 13:01:57]
I have charts that are linked and are used with my watch list. When I open a trading dom for one of the linked chars and then change the symbol on the watch list, the trading dom does not change symbols and I can not figure out how to link the dom to the chart so that it changes when the chart symbol is changed.
[2013-08-02 13:06:00]
This is done through Chart >> Chart Settings:
http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#LinkNumber
[2013-08-02 13:07:08]
Disregard the last reply. I finally figure it out using the chart setting on the dom
