Date/Time: Sat, 23 Nov 2024 17:40:14 +0000
Software not working
View Count: 1572
[2013-08-01 12:00:47]
User55472 - Posts: 3
I get the following message when starting Sierra
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Please assist.
Mark
[2013-08-01 16:54:00]
Are you running any custom studies?
If so, follow the instructions in help topic 17 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html
[2013-08-02 07:28:32]
Hi, thanks for the reply. It is for a specific machine. It is running Vista and I have downloaded Sierra plus the Microsoft files. I have adjusted the settings to see if the firewall is preventing it from running, but it is still refusing to start. Anything else I can do besides buy a new PC?
[2013-08-02 11:08:17]
Please install Sierra Chart into a new folder on your system. For example: C:\SierraChart2. Download and install the non-CLR version with this link:
https://www.sierrachart.com/downloads/SierraChartSetupNoCLR.exe
Let us know if there is any problems getting Sierra Chart started.
[2013-08-05 17:52:52]
Thank you Sierra team, up and running.
