Date/Time: Sat, 23 Nov 2024 16:51:08 +0000
Changing Target Size Leaves Incorrect Target/Stop
View Count: 2070
[2013-07-31 18:45:30]
acuity - Posts: 10
Using an OCO with 5 targets. Once filled, if I change individual target amounts via the New Quantity and Price window from the DOM , leaving the total contracts the same, when the stop is hit, all orders are cancelled correctly, but it still shows me with a position.
If I scale into the position, half at a time, and do the same target size adjustment described above, when stopped out, it correctly shows me flat, but leaves a target order.
Only when I leave all original orders alone, does the complete OCO order behave correctly.
Stumped??
[2013-08-01 00:28:03]
We need more details. And a very specific example we can follow. As simple as possible that still shows the problem.
We need to know the order quantities and specifically what orders you are adjusting.
[2013-08-01 12:42:27]
acuity - Posts: 10
I created a 5 target, one stop OCO; each target is two contracts. When I adjust quantities on two targets in the DOM (keeping the total contracts constant - adjusting one target down, and the other up by the same amount), after a target is filled, and then the stop is hit, I am either left with an 'orphan' target, or no orders and a position. I have tried this with all in (one order), or scaling in half and half - same problem.
[2013-08-02 00:45:58]
We understand this better now and what you are experiencing is normal behavior because each of the 5 targets establishes a separate OCO Group. So if you increase the quantity of a Target in its OCO group but the stop has a lower quantity, it is going to cause the Target to still remain when the stop fills.
[2013-08-02 00:56:36]
Actually, as we think about this, there is a simple solution. On the Trade Window for the chart or Trade DOM enable Menu >>Maintain Same Quantity for OCO Group Orders.
[2013-08-02 01:36:24]
acuity - Posts: 10
Will this work if I scale in, say half and half?
[2013-08-02 03:12:32]
It's hard for us to say because we do not have a clear enough understanding of specifically what you are doing. Just simply try.
