Date/Time: Sat, 23 Nov 2024 16:47:13 +0000
Comfirm Order
View Count: 1269
[2013-07-31 15:27:37] |
User29707 - Posts: 43 |
Using the trade dom, I get a confirm order box even though I have not selected any confirms in the setup. I really want instantaneous orders but this window will just not go away. Any suggestions |
[2013-07-31 16:59:21] |
You need to disable the order confirmations as explained here: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
