Date/Time: Sat, 23 Nov 2024 17:35:55 +0000
Volume by Price : separate Peaks and Valleys functions
View Count: 1689
[2013-07-30 20:30:05] |
Tintin - Posts: 23 |
Hi SC team, Here is one request for the Volume by Price Study. Is it possible to separate the Peaks and Valleys functions in order to choose what we want to see on the chart for example only Peaks or only Valleys or both ? Regards. Tintin. |
[2013-07-30 22:07:59] |
User14266 - Posts: 225 |
Yes please. I have no need to see the valleys. I don't use the P&V feature because of this.
[2013-08-01 07:44:55] |
We will see about this.
[2013-08-03 04:00:24] |
Al SC Developer - Posts: 434 |
This will be available in ver 1005 when available. The Draw Peaks & Valleys input will contain options for Both, Peaks Only, or Valleys Only.
