Date/Time: Sat, 23 Nov 2024 17:21:41 +0000
Attached Order Problem
View Count: 1226
[2013-07-30 16:20:05] |
robwa - Posts: 5 |
I am attempting to use Attached Orders for exits in my autotrade system. I have a simple bracket trade strategy set up, exactly like your default Trade Window configuration. Parent and Child orders are submitted correctly by the autotrade logic. When an order is filled, after a few minutes (sometimes seconds), the Child orders simply disappear from the system and the chart. This happens if the chart is in Trade Simulation mode or if orders are sent to IB TWS (simulated). Occasionally, the position is held until the target or stop is hit. I was previously using cells L3 and N3 in the autotrade spreadsheet for exits, and had no problems. |
[2013-07-30 17:15:02] |
When you see the child orders disappear, is the position closed or flattened? You can see exactly what has happened with all of the trading activity through the Trade >> Trade Activity Log: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
