Date/Time: Sat, 23 Nov 2024 17:10:57 +0000
Additional Features
View Count: 1404
[2013-07-30 06:03:58] |
User92023 - Posts: 6 |
hi i think it will be more clear that if in the 'Packages Table' Section you will add another Column that referrals to the "Tools >> Draw Volume Profile tool. This requires Package 5" because for me . it is the only reson to purchase package 5 and not package 3 and yet, if i hadn't read the 'additional features' that package 3 is marked with a 'v'... (the same you did in the 'package table' with the 'tpo chart study' and the 'number bars' that have their own column ) thanks !
[2013-07-31 06:48:12] |
We will look into this.
