Date/Time: Sat, 23 Nov 2024 17:24:49 +0000
OpenChartOrGetChartReference questions
View Count: 1456
[2013-07-29 21:10:30]
onnb - Posts: 662
1. using IBPT_NUM_TICKS_PER_BAR, I would set the number of ticks in IntradayBarPeriodLength?
2. DaysToLoad - is there a way to access this from the chart settings? I want to open the the new chart with the same number of days as the current chart.
Onn
[2013-07-29 21:55:37]
1. Yes.
2. Do you mean get the current days to load for the chart the study instance is on?
[2013-07-30 05:01:23]
onnb - Posts: 662
2. yes
[2013-07-30 09:01:45]
In the next release, you will be able to set DaysToLoad to 0 and this will use the setting from the chart the study is applied to.
Updated documentation:
DaysToLoad : This sets the number of days of data that will be loaded into the chart whether it is a Historical Daily chart or an Intraday chart. If this value is left at 0, then the Chart >> Chart Settings >> Use Number of Days to Load >> Days to Display/Load setting of the calling chart is used.
Date Time Of Last Edit: 2013-07-30 17:35:55
