Date/Time: Sat, 23 Nov 2024 16:52:53 +0000
Can't see intraday data from 3/15 through 4/22 using 5 min charts on TT ES contracts
View Count: 1381
[2013-07-29 14:01:12] |
User77118 - Posts: 10 |
Can't see intraday data from 3/15 through 4/22 using 5 min charts on TT. I am using the 5 minute bars and continuous futures contract. If I look for June contract only it only goes back to April 22, missing data. |
[2013-07-29 16:17:17] |
Sierra Chart - Max - Posts: 5730 |
1. You will need to re-download the data for the ES chart by following these steps: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html#RefreshWithData 2. On the servers the June Contract goes from 2013-02-01 to 2013-06-21. Please follow the steps linked above above to delete and download the data. Sierra Chart Support Date Time Of Last Edit: 2013-07-29 17:05:20
[2013-07-29 17:05:43] |
Follow the instructions in help topic 42.1, if you still have a problem: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
