Date/Time: Sat, 23 Nov 2024 17:29:15 +0000
Only able to draw horizontal lines on 0.5 pip increments
View Count: 1350
[2013-07-29 12:46:42]
User26129 - Posts: 6
apologize if I am missing the obvious here. But it seems I am only able to draw a horizontal line in 0.5 pip increments, ie on EURUSD every 1,32800, 1,32805 etc. As I look at very low timeframes that makes plotting lines quite inacurately and frustrating.
Any way to work around that?
Thanks!
[2013-07-29 17:29:54]
You need to disable Chart >> Chart Settings >> Advanced Settings >>Adjust Tool Values to Tick Size.
