Date/Time: Sat, 23 Nov 2024 17:08:03 +0000
SC, basic suggestion...an option to the hand tool
View Count: 1610
[2013-07-28 01:13:00]
abrown8703_ - Posts: 4
SC, would it be possible to add an option to the hand tool, which would display just the price of the current tool location. Why?
1) using a remote desktop software such as Teamviewer or Logmein only gives limited real estate to view the platform. Knowing what price the tool is displaying is difficult.
See sample images. One from Desktop, one taken using Logmein on iphone.
image2013-07-27 21.05.25.png / V - Attached On 2013-07-28 01:09:13 UTC - Size: 61.29 KB - 582 views
image2013-07-27_2055.png / V - Attached On 2013-07-28 01:09:45 UTC - Size: 50.95 KB - 504 views
[2013-07-28 20:42:11]
User14266 - Posts: 225
+1
[2013-07-29 22:26:56]
You could enable Global Settings >> Tool Settings >> Chart Values >> Always Active On When Using Other Tools. And then use the Compact Tool Values window to see the values.
[2013-07-30 00:27:58]
abrown8703 - Posts: 64
Thanks for your suggestion. I have looked into that before, however, its the limited real estate(4 inch screen) on these mobile devices. The compact tool, unfortunately does not work well. I would encourge you to use Teamviewer, Logmein or any other app for remote access to get the gist of what I am really asking. And its only the "Y" axis or price value that I'm requesting. As hand tool moves, price is displayed. See attached example.
Date Time Of Last Edit: 2013-07-30 00:29:57
imageScreenClip.png / V - Attached On 2013-07-30 00:27:53 UTC - Size: 1.46 KB - 487 views
[2013-07-30 02:07:25]
The Compact Tool Values Window is customizable through Chart >> Chart Settings >> Advanced Settings >> Settings. See attachment.
imageImage340.png / V - Attached On 2013-07-30 02:06:52 UTC - Size: 1.43 KB - 480 views
