Date/Time: Sat, 23 Nov 2024 17:28:41 +0000
[User Discussion] - Drawing TPO Value Area Lines on Candle Chart
View Count: 1538
[2013-07-27 16:41:09] |
User23815 - Posts: 210 |
This is a second request. It was not answered from several days ago. I am using the study TPO Value Area Lines on a Candlestick Chart. Currently it draws a line at each of the values. Is it possible, without a spreadsheet study, to draw the area lines the same width to match where they would be on a TPO chart? For example, I have my tick price increment set to 5, so on a TPO chart that would be the size of the line based on the price and volume action. And is it possible to make them transparent. I have drawn them behind the main graph but was wondering if there was a choice for making a color transparent. Thanks |
[2013-07-29 22:57:24] |
This is not within the scope of our support. This is marked as a User Discussion. For all of the documentation on graphics and appearance settings for studies, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#SubgraphsTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
