Date/Time: Sat, 23 Nov 2024 17:30:30 +0000
VbP Peaks & Valleys
View Count: 1539
[2013-07-27 05:34:38] |
omni72 - Posts: 17 |
Hi SC Support - I just recently noticed that the peaks/valleys are no longer drawn to the end of the period - is this by design? I'm running v1000 but saw the same behavior with v999 and v997. Instead of drawing to the end of the period, it just draws the lines to end of the volume line. It also seems that if using anything other than 0% Transparency, it is difficult to see the P/V's at all. If I can find a screenshot of older versioned VbP charts, I'll add it. For now, I've just added one of the current version. Thanks and take care - omni Date Time Of Last Edit: 2013-07-27 05:38:09
SCv1000-VolByPrice-PeakValleyLines.PNG / V - Attached On 2013-07-27 05:38:03 UTC - Size: 68.73 KB - 506 views |
[2013-07-27 10:04:31] |
We will check on this.
[2013-07-29 14:24:53] |
Al SC Developer - Posts: 434 |
The peaks and valleys lines will be addressed in ver 1001.
