Date/Time: Sat, 23 Nov 2024 16:55:03 +0000
URGENT: Sierra Chart on Two Computers
View Count: 1750
[2013-07-25 15:42:30]
drywater0 - Posts: 85
I am currently a package 5 monthly subscriber using SC on my desktop PC. I will be traveling and would like to use it on my laptop. I know that I can have multiple copies running on a given PC, but can I install and use the program on my laptop if I do NOT use it on my PC simultaneously? I would appreciate if you could respond promptly because my monthly renewal is tomorrow. Depending on your answer, I may have to suspend the PC subscription and create a new account for my laptop. I would prefer not to do it this way because I will only be away for two weeks and will effectively "waste" the second half of the month subscription if I need to reactivate on my desktop upon my return. Please let me know what you think the best / easiest solution would be. Many thanks in advance for your help.
[2013-07-25 15:56:40]
ganz - Posts: 1048
drywater0
hi
http://www.sierrachart.com/index.php?l=doc/PurchaseInformation.php#Licensing
imho this is for direct accounts w SC
gd lck
[2013-07-25 16:06:49]
Thanks for your response. I didn't recall that paragraph when I initially signed up. It seems as though I can use on two computers (even simultaneously) as I have a direct account with SC. Appreciate your help.
[2013-07-25 16:32:47]
Sierra Chart - Max - Posts: 5730
With a package 5, you are able to use it on 3 computers simultaneously.
Sierra Chart Support
[2013-07-25 17:09:51]
To confirm, you can use Sierra Chart on 2 computers at the same time and you can install Sierra Chart on as many systems as you want.
Date Time Of Last Edit: 2013-07-25 17:10:07
