Date/Time: Sat, 23 Nov 2024 15:12:54 +0000
Adjust how far chart can scroll?
View Count: 1467
[2013-07-24 22:34:23]
WarEagle - Posts: 73
Is it possible to get the chart to scroll further into the future than what I am seeing? On the attached 4 minute chart I have scrolled until the time stops 10 hours into the future, after that there is just blank space on the time axis but the cross-hair cursor won't track there and I can't draw a vertical line in that space. I would like to be able to plot drawing objects on the chart for the next day (or even two) in advance.
Thanks!
imagefuture_times.png / V - Attached On 2013-07-24 22:26:46 UTC - Size: 21.57 KB - 493 views
[2013-07-25 02:50:27]
In an upcoming release, there will be a new option added to Chart Settings to set the number of right side fill space columns. So this number can be increased over the default.
