Date/Time: Sat, 23 Nov 2024 15:35:38 +0000
ATM Strategy
View Count: 3050
[2013-07-24 13:19:04] |
Theo McCloe - Posts: 8 |
I have been trying to setup a 3 position trade strategy I found on a Optimus video I followed instructions and it just won't save or configure. I went to targets tap and entered my targets as limits as targets 1,2 and 3. I entered stops as 1, 2 and 3 because I do not have the option in the drop down for stop all. I then went to "M" menu and configured. When I click on the saved strategy it doesn't work.
[2013-07-24 16:39:38] |
Please follow the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#AttachedOrderWindowInterface It is the OCO Group list box which contains All OCO Groups. Not sure why you conclude you cannot "Save or configure" Attached Orders. You should have no trouble at all saving the configuration. But that is not even necessary. Make sure you have enabled Use Attached Orders on the first tab of the Trade Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
