Date/Time: Sat, 23 Nov 2024 15:21:40 +0000
Forex Data with IB
View Count: 1447
[2013-07-24 13:04:32] |
User75564 - Posts: 42 |
I receive Forex Data with IB. Chart trader doesn't show order filled. Market Order shows 0 Currency and 0 ticks.
EUR.USD-CASH-IDEALPRO 15 min #1 41479.543.png / V - Attached On 2013-07-24 13:03:03 UTC - Size: 38.43 KB - 511 views |
[2013-07-24 16:27:17] |
The problem is your order quantity is much too small. You should use at least 10000. In regards to not seeing the order fill on the chart, do you have Trade >> Show Order Fills enabled? Is your computers clock set accurately. Refer to help topic 38 here: http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-24 16:29:08
