Date/Time: Sat, 23 Nov 2024 15:16:59 +0000
Import workspace
View Count: 2132
[2013-07-23 21:00:52]
User30818 - Posts: 1
Im trying to import a workspace from another user and have it saved on desktop but cant figure out how to get it into sc
[2013-07-23 22:08:00]
Sierra Chart - Max - Posts: 5730
You will need to copy the files into your Data Files Folders, which you can find under Global Settings >> General Settings.
If you are referring to a Chartbook file, after you copy the Chartbook file to the Data Files Folder you will be able to open it by selecting File >> Open Chartbook.
If you are referring to a study collection or a DLL file, please see:
https://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html
Sierra Chart Support
Date Time Of Last Edit: 2013-07-23 23:24:31
[2013-07-23 23:24:02]
If the workspace are referring to is a Sierra Chart Chartbook file, then after you copy the Chartbook file to the Data Files Folder you will be able to open it by selecting File >> Open Chartbook.
