Date/Time: Sat, 23 Nov 2024 15:36:19 +0000
VbP last bar inclusion suggestion
View Count: 1586
[2013-07-23 03:12:43]
joshtrader - Posts: 488
When I draw a volume profile, the end time is set to the start time of the last bar included in the range drawn.
Let's say you draw a VbP on a 30 minute chart, which has a 9:30:00 to 15:59:59 session display time. The resulting profile will include the final bar as intended. However, if I switch to a 5 minute chart, the last 5 bars (starting with the 15:35:00 bar) will be excluded, because the end time of the profile is still set to 15:30:00.
So my suggestion when drawing a VbP is to set the VbP end time to be the start time of the following bar less 1 second.
This is important because a drawn volume profile is intended to be inclusive of all data in the final bar drawn, and a time frame switch should not alter that IMO.
Thank you for your consideration!
[2013-07-24 05:22:53]
We will look into this.
[2013-07-24 19:01:59]
Al SC Developer - Posts: 434
This change will be available in ver 1000 (when available).
