Date/Time: Sat, 23 Nov 2024 16:43:04 +0000
[Locked] - windows and chartbooks
View Count: 1544
[2013-07-22 03:19:48]
teowinner - Posts: 16
hi,
can u guys look into this function, it seem like after rearrange the chart order, it doesn't save, repeat many times, save all,etc, closed and reopen the chartbook, it not register the change.
thanks!
[2013-07-22 18:06:35]
We tested the Windows and Chartbooks window and the reordering of the chart windows in that list does save even after reopening the Chartbook.
[2013-07-25 05:53:43]
hi guys,
pls see attached the cut outs;-
first copy which is set in sequence so the chart will be one on top the other.
second copy show that it does not after closed and open again.
hope this can be look into, thanks!
imagewindows and chartbooks.JPG / V - Attached On 2013-07-25 05:52:46 UTC - Size: 142.01 KB - 566 views
imagewindows and chartbooks2.JPG / V - Attached On 2013-07-25 05:52:54 UTC - Size: 135.54 KB - 580 views
attachment12345.cht - Attached On 2013-07-25 05:53:28 UTC - Size: 150.54 KB - 500 views
[2013-07-25 09:48:24]
So you are referring to the order in which the windows appear after they are opened. Not the order of the chart windows in the list.
Ultimately the order in which these windows are layered, as they are opened up is controlled by the operating system. We cannot help with this. We have no control over ultimately what the operating system is going to do.
We cannot spend further time on this. This is marked as resolved. We simply cannot help with this at all. We will not spend further time on this.
Date Time Of Last Edit: 2013-07-25 10:46:11
