Date/Time: Sat, 23 Nov 2024 14:40:13 +0000
Historical Tick Chart
View Count: 1519
[2013-07-19 06:54:11] |
c9038281 - Posts: 3 |
Hi, 1. I want to view historical intra-day data for the S&P 500 mini. Can someone tell me how far back I can access if I have plan 3 (with additional features). I seem to only be able to view 2 years worth - is this correct? If so, how can I get more without going to an external provider. 2. I created a 1 minute chart, but want to create a tick by tick chart also. Can someone point me in the right direction? Many thanks for helping me out here. C |
[2013-07-19 16:33:29] |
Sierra Chart - Max - Posts: 5730 |
For Tick Data, you will need to use the following service: http://www.sierrachart.com/index.php?l=doc/helpdetails54.html You will be able to get data back to 2007. To download more data than you currently have, please see: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support |
[2013-07-19 19:09:06] |
1. Refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html 2. Use this Data service: https://www.sierrachart.com/index.php?l=doc/helpdetails54.html Follow the instructions here to set the chart to 1 Number of Trades per Bar: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-19 19:09:52
