Date/Time: Sat, 23 Nov 2024 14:17:35 +0000
User Email Questions
View Count: 1484
[2013-07-18 17:18:57] |
Sierra Chart - Max - Posts: 5730 |
Is it possible to overlay an intraday study in a daily chart? I tried using the Overlay Study to overlay the volume by price of an intraday ESU3 to a daily ES# chart. I am trying to do it this way, because I can get the bid/ask volume on the intraday chart, where I can’t get it on the daily/historical chart. Any suggestions would be great. Thank you in advanced. Sierra Chart Support |
[2013-07-18 21:33:02] |
amk44 - Posts: 10 |
IS IT POSSIABLE TO PUT A 50% RETRACEMENT ON ZIG ZAG STUDY
[2013-07-18 22:05:14] |
1. Using the Study/Price Overlay study, you can overlay a study from one chart on to another. However, you cannot overlay the Volume by Price study due to how that study works. 2. Not sure what you mean by 50 percent retracement on the zigzag study. There is a Price Retracement drawing tool on the Tools menu if that is what you are referring to. Refer to Chart Drawing Tools in the documentation for more information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
