Date/Time: Sat, 23 Nov 2024 14:25:25 +0000
Copy drawings to another chartbook that were created with ACSIL?
View Count: 2112
[2013-07-18 15:24:53]
User45685 - Posts: 36
I have a working custom study running which creates drawings in pure ACSIL and is not tagging them as userdrawings so that i dont have to delete evrything manually:
s_UseTool Tool;
    Tool.Clear();
    Tool.ChartNumber = sc.ChartNumber;
    Tool.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
    Tool.LineNumber = LOW_LINENUMBER_BASIS + sc.Index-2;
    Tool.BeginIndex = sc.Index-2;
    Tool.BeginValue = sc.BaseData[SC_RENKO_CLOSE][sc.Index-3];
    Tool.EndIndex = sc.Index;
    Tool.EndValue = sc.BaseData[SC_RENKO_OPEN][sc.Index-2];
    Tool.Color = LOW_COLOR;
    Tool.SecondaryColor = LOW_COLOR;
    Tool.TransparencyLevel = TRANSPARENCY_LEVEL;
    Tool.LineWidth = RECTANGLES_LINE_WIDTH;
    sc.UseTool(Tool);
The drawings are done/performed on renko bars, but it seems that i cannot transport/overlay these drawings onto lets say a 1 Minute timeframe chart.
Is there any solution to this? I tried useing the Study/Price overlay study but it does not seem to work. Suggestions?
[2013-07-18 17:48:32]
You can do this by setting Tool.AddAsUserDrawnDrawing = 1.
And then specify the Tool.ChartNumber to output the drawings to.
Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html
To delete a drawing programmatically use:
http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#scDeleteUserDrawnACSDrawing
Date Time Of Last Edit: 2013-07-18 17:49:44
[2013-07-18 18:33:28]
Quick followup:
If i set the Chartnumber to output the drawings to to a different chart, will the original chart where the study is run also have the drawings?
Example:
The rectangles are currently drawn into chartnumber 3 where my renko bars are displayed, assuming i want a copy of this onto chart number 1 where a 1 minute timeframe is running and i adjust the code to include the AddAsUserDrawnDrawing and set the chartnumber output to 1... will chart number 3 also have the rectangles or will ONLY chart number 1 where the output has been selected to have the drawings?
[2013-07-18 22:12:23]
The drawings will be added only to the chart specified by Tool.ChartNumber. So you need to add the drawing to each chart. And delete it from each chart.
[2013-07-18 23:55:11]
Ah this clarifies it, time to rewrite the code then i guess =/
Is drawing to multiple chart numbers supported? I.e Specifying:
Tool.ChartNumber = 1, 2
in order to draw it to chartnumber 1 and 2 ?
[2013-07-19 00:33:28]
No. You have to make 2 separate sc.UseTool calls.
[2013-07-19 00:44:06]
Thanks!
Consider the support request resolved :)
Good night!
